HC2 Offline and no lan settings possible
after a system crash, the HC2 could not start (starting services). After a few restarts without success I tried to recover the HC2.
This worked without problems. The current version is now 4.580. But now, the status is "offline" and I can't change the lan settings (only loading page)!
The api interface also cannot load network settings.
What can I do? No Internet connection is possible!
Any suggestions?
11 answers to this question
Hi @diveng, have you tried resetting the IP address?  Some further info here:
    Hi Tim_,
    yes I have already changed the IP address.
    I can access the interface from lan, but not from Internet.
    /monthly_2020_09/backu.png.6f0b2b58a03e5fa56bc7c8f5013fee88.png" />
    Any other idea?
    @diveng
    offline for the app or
    is de gateway correct in youre hc2, most of the times same as youre router ip.
    @akatar
    i can't config the lan configuration! Neither in the interface nor via api.
    But Interface is local (lan) available.
    @diveng
    Perhaps @tinman has an idea. (else contact fibaro support, because there is something wrong within the firmware.)
    (i assume that the hc2 is NOT in dhcp mode? ifso, disable that)
    Edited by akatar
    @akatar no, the hc2 is in dhcp mode, because i changed the ip on my fritz.box. And the new IP works also.
    @tinman do you have an idea?
    @diveng please, set dhcp off, and do the settings manual and test again
    On 9/14/2020 at 5:06 PM, diveng said:
    if your Homecenter is in this state, why would you need it to be connected to internet?
    Shouldn’t you first solve the issue by local access?
    support need to check what's wrong, having fritzbox might be as well "filter problem on fritzbox"
    @tinman I think  it's no problem with the fritzbox. I don't changed the settings on the fritzbox.
    @SmartHomeEddy the h2c works fine and i can change everything on the interface except internet access.
    Did you ever get this sorted as i have the same issue with Starting Services stuck on my 10 month old HC2 Black.
