S2 on Dimmer2 / Hue motion sensor
1rst I like to have a option to select the S2 (second input) on a Fibaro Dimmer2 module. Now i have to get into the parameters (scene id 26) to use is (only after switching scene on). I realy like to just to select the S2 button like in Homey. I want to use the S2 to toggle Fibaro wall plugs.
2nd i have 2 HUE motion sensors that wont show in the HC3. The bridge of the HUE does and also all (6) lamps/spots/LED strip. I can see the sensors in the HUE app itself and they also work.
