Communication problem
The HCL controller has a total of 12 thermostats. Everything worked great last season. But recently I discovered communication problems. All nodes are dead. Moreover, it can be seen that the data from the temperature sensors are being updated, but it is impossible to change the temperature setpoint. Communication problem. It seems that the devices remember the controller and transmit data to it, but the controller has forgotten about all its devices. What to do? Help..
You may start your investigation from reading your system logs. Unfortunaly the option is no longer work in 4.600 firmware due to
So you will need to flash custom recovery image, and then custom fw (with ssh password login enabled)
Edited by jack.daniels
Updated with topic link
