SirRekt 0
Hi there,
I got a roller shutter 3 which controls via two contactors a 12VDC motor. I calibrate it by time of UP and DOWN movement but when it gets DOWN and i press again the DOWN button trigger, it makes another cycle down, the same happening when getting it up.
There is any way, maybe by lua script (which i'm not an expert in) to tell the roller shutter 3 that if it's in DOWN position it should go ONLY UP and if it's in UP position it should go ONLY DOWN?
Thank you so much!
