RiccardoCanetta 13
Hi, I have a SmartImplant connected to 2 different analog sources (parameters 20 and 21 set to 0, as they are both NC). The problem is that after a power-failure of the SmartImplant (HC2 is under UPS) both sources ignore a full cycle (open/close) before they start working again. So basically after power failure, I open gate, it's not reported, I close it and then SmartImplant starts working again - and same for the other source which is a rain sensor (it rains, it's not reported, it dries and then SI starts working when it rains again)
Has anyone else noticed the same? Is there a way to trigger a "status update" via LUA? I have tried Soft Reconfigure and it doesn't help...
Thanks!
Riccardo
11 answers to this question
