JayZbird 0
Hi All-
I hoping for some advice wiring up the smart implant to activate my Liftmaster Roboslide gate opener. I read the instructions on gate openers, but am still confused about how to install the implant. The wiring diagram for the gate remote (I'm assuming this is what I should tap into) is attached. It seems the default setup only gives you the ability to emulate a click of the remote that will toggle open/close. To really be "smart", I'm wondering if there is a way to integrate one or both of the gate's limit sensors to identify whether it's open or closed (these are little switches that I believe shut off power or send a signal back to the main gate controller when a little rotating gear has travelled a certain distance and physically activates the switch–they have 3 wires going into each sensor, and one of them drops to nil when the switch activates). Really only one should be necessary to determine the state of the gate, since if one is open the other should be closed unless stops partway. I'm unclear if I can wire these directly into the implant or if I need another module? The whole system runs on 12V DC, and it seems the supplemental voltage sensors only go up to 10V?
Thanks in advance for any help.
8 answers to this question
