Which led driver to use with Dimmer 2
I have 6 x 6W led/500mA that I need to dimmer with a unique driver TRIAC.
Do you know any compatible driver that works?
Giorgio
Will depend entirely on your market.
I have found recently it's hard to get a perfect match with specs this specific ( (is that why they are called specs? ?)
What is wrong with the OEM drivers?
Are you trying to series drive many lights with one driver instead of 6x PEM drivers? Why bother? Figure 8 them and be happy, and don't stress the first LED in the serial chain.
Do you really have these 6x LEDs without an OEM driver? Ok, if so, you can broaden your horizons (but also deepen the level of research required) by finding similar LED/driver combos that will meet your need - I found that by looking for "ready to go" LED/driver combos I could ditch the LED and be left with a driver that isn't otherwise available on the market on its own.
