NLWaard 12
Trigger 'sceneActivation' will not be reseted.
On a Dimmer 2, with parameter 28 'scene activation functionality' activated,
I can't activate a scene with the same butten press type twice in a row (for example a single click (16)).
Only the first call will activate the scene. Then it will not activated the scene on the same butten pressed again.
Scene trigger:
Scene action:
If I do the same thing in a quickApp loop, the last called value 16 (single click) will be displayed several times.
And in a QuickApp (it's also strange not to call BttnPressed.value ??):
View:
This shows that it will not be reset.
Is there a method that can call to reset it to nil?
Now I can't use this function because you can't use the same click twice in a row?
Edited by NLWaard1 answer to this question
