Just a small point. Added a temp controller with temp sensor in HC3 All went well, but temp sensor shows 0% battery. Its new and working so i think this is unlikely although i could change it and see. Is it a known issue?
Does the LED of the heat controller shine ?
Connect the heat controller with a external power source (like to charge it) and check what happens. Any changes ?
Next, try a restart of your HC3  - any changes ?
Exclude/delete the device and add it again  - any changes ?
    Hmm, thanks.  Basically try every option possible and see if something changes? I guess its not a known problem then :-)
    Did you ever solve this? Happens for me as well. Support said I should try reconfiguring the device if it's not fixed in 2 days by itself..
