Actual scene ID identification in LUA -- HC3
I want to use the following code in HC3
fibaro.scene("kill",31);
The nr 31 is the same scene ID where I want to use the "kill" function.but I need to use for this value as parameter.
Can you help me how can I get the actual scene ID in LUA code ?
In HC2 there is an easy command --> fibaro:abort(); and I want to use this function in HC3.
You don't need "kill" the scene. In HC3 only one scene instance could be run. In case another instance triggered (started) the previous instance "killed" by the system.
