https handshake certificate error
Hi
I take data from the buienradar website.
On the website is mentioned I should use
that then will take you to
The website mentions however I should not use the website you are taken to but the "getrr.php" url
However, this gives me the following error:
  Handshake error: certificate verify failed
Is someone who knows how to use the php url in a scene?
10 answers to this question
In my HC3 QuickApp I use
"https://br-gpsgadget.azurewebsites.net/data/raintext"
(with latitude an longitude attached)
That works for me
    That works for me
    Me too but I get an empty result some times a day.
    The buienradar website mentions
    "[Update 20 juli 2017]: Afgelopen dagen gaf deze widget geen data door. Dit is inmiddels verbeterd. Gebruik hiervoor de url
     en niet de onderliggende url.
    Edited by Twannie
    Me too sometimes empty or sometimes less than 2 hours. I can handle that in the code. I think it is "normal".
    maybe... the remark does not say "don't use underlaying url" for no reason I would think
     does a forward to:
    Won't that be a problem?
    what do you mean by problem?... the error?
    but the text tells us not to use the second link directly
    Maybe just try it. It is a note from 2017
    it works as we know, just wondering why the certificate message appears when using php
    Ah, just curious
    26 minutes ago, SmartHomeEddy said:
    Ah, just curious
    and want to know if the php url also gives no data sometimes ?
