In LUA turn off a SCENE so it wil not be triggerd (Also turn it on again in lua)
Guest Ravaoo
I made a virtual device. In this device i want to get (with lua script) the status of a scene, turn it off and turn it on again. I dont mean killing instances of running scripts. I want to deactivate the scene so it is not triggerd any more.
Example: I have a scene that is triggerd bij klok to start sprinkling my lawn for half a hour. Of i turn the scene off in the fibaro HC2 webinterface, it wil not be triggerd again.
Thanks for your response
5 answers to this question
Guest Ravaoo
    43 minutes ago, jgab said:
    --Deactivate scene fibaro:setSceneEnabled(<scene ID>, false); --Activate scene fibaro:setSceneEnabled(<scene ID>, true);
    Thanks. Just wat i need.
    And how doe i get the current status?
    fibaro:isSceneEnabled(sceneID)
    Guest Ravaoo
    I see i have still a problem. When i disable de scene with the switch in the interface, it is not set to disabled but to manual. Is there a function the get and set this status?
    Or better, is there an manual for all these kind of commands and functions?
    fibaro:setSceneRunConfig(sceneID ,"MANUAL")
    fibaro:getSceneRunConfig(sceneID)
