Tobian 0
I've recently installed 6 x Dimmer2 switches with LED lights.
Everything seems to be working well with control over the lights working via a physical switch or via the Vera Edge controller.
Every night at 9.26pm (GMT + 10) and again at 9.56pm I get all lights flashing on and off for about 60 seconds. Every light with a dimmer flashes. I've tried installing a Bypass on one of the light circuits - this has had no effect.
Any suggestions on how to troubleshoot this issue?
It may also be flashing at other times, but these are the two times I know it happens every night. Lights with no Dimmer 2 do not flash. Disconnecting the Vera controller has no effect - the lights flash at these times.
7 answers to this question
