I have a number of Fibaro relay switches which have not been removed from a previous system. I have tried to reset them by pressing and holding the "B" button but I still can't add them. How do I know if the resetting process is successful and a device is ready for addition to a new system?
Please help
You do this most easily in your controller with the function "Remove (delete) Device" to remove the device from the Z-wave network.
Then you can use "Add Device"
Remove as Dreambox wrote.
If relais on power push B button 3 sec and add.
Succes,
//Sjakie
    Thanks for that.
    I've managed to work some (but not all) of them. I'm wondering why resetting does not work. Are there any other solutions?
    @Pav The procedure for adding is 3 press (3x click). It is also removed. Not pressing for 3sec.
    It takes a little practice. Please try again.
    eM.
    • 5 weeks later...
    Hello All,
    If you have any problem regards AC.
    ? Get Repair your air conditioner quickly in NJ, AC service & repair contractor available in New jersey at OM HVAC.
