CHBD 0
Hello all,
I would like to make my garage gate smart. I think that the FGS 224 or FGS 214 modules are the right ones, because I need potential free contacts, as it is stated in the manual. (Rademacher Rator, approx. 20 years old, but still properly working![;-) ;-)](https://forum.fibaro.com/uploads/emoticons/default_wink.png)
Currently I already have installed a momentary switch (one button) to control the movement of the gate ( up, stop, down).
Now I would like to set up a FGS 224 or FSG 214 to control the gate via Fibaro.
I already have some experince with roller shutters and heaters but unfortunately not with a relay switch.
Can you guys please help me to wire the it correctly?
Is it correct to use tgr IN and Q1 teminal to connect the relay switch with the momnetary switch?
Which settings do I have to use? I just ne a short pulse to start and stop the movement of the gate.
Does the FGS 214 have any advantages over the FGS 214 for my "project"? The state of the gate is transmitted by a position sensor which is attached to the gate.
Thanks in advance.
Chris
Thanks in advance!
Chris
Edited by CHBDLink to comment
5 answers to this question
