FIBARO - HC3 - SMARTTHINGS integration
Hi!
I'm a new user to fibaro, z-wave and smart products in general. I just finished building my new home and used Fibaro prudects to smart it up.
I have about 70 Fibaro devices and work with HC3.
I wanted to try a few things with integrating Fibaro's zwave devices with wifi devices so I turned to smartthings.
I can see on Fibaro's website that it now works with smartthings.
more specifically, according to the site "from now on FIBARO is one of the manufacturers included in the environment that can be managed within the app."
However…. Fibaro do not appear on Smarthings app when wanting to add a device.
Nor Fibaro devises nor Fibaro as a manufacturer. It has a lot of manufacturers brands but Fibaro is not one of them.
Is there a way to integrate fibaro devices with smarthings without using the smartthings hub? Is there a way to use the smarthings app with HC3? or… is there a way to add wifi devices to HC3?
Itay
Hi, did you ever find an answer to this?
I started
