FamSetsaas 0
I have a Fibaro wall plug, where I need to measure the power (when a load is added, I trigger an operation).
This works fine, but my script seems to be triggered a lot due to minor power fluctuations.
In the idle state, the power typically fluctuates between 0 and 0.3. I have written the script to ignore these minor changes, so that in itself is not a problem.
But my question is whether I can change the wall plug to ignore these small changes.
Looks like changing parameter 10 (high priority power report) and 11 (standard power report), as they both operate in percent, which does not help as the base value is 0.
I've tried changing parameter 13, but it does not seem to have any effect.
Any ideas how to tell the wall plug to ignore the minor power changes?
Br
John Erik
