Autotec siren 6 on HCL - Turn On & Off via Scene issue
I bought Aeotec Siren 6 and I added to HCL and HC3. With HC3 the siren compatible. You can create scenes to turn on and off siren , to volume up and down (0-100% volume), select multible sounds etc.
The problem is that I want to use this siren with HCL. I added siren to HCL and eight sounds (2 of them are the same) was added. The problem is that I cannot turn on the siren via scene. The functions that can be selected are Arm, Force Arm, Disarm, Initial State and Opposite State but neither of them can Turn the Siren On and Off
Is it possible to create a scene to turn On and Off the Autotec Siren 6 on HCL ?
Edited by Prokopis Bor
7 answers to this question
Hi, I have the same problem!
add it scenes, but not possible to get any sound from the siren6.
trying manualy all the ringtones are available.
No answer yet from anybody yet??
Wich firmware has youre doorbell6?
Look here
and on the forum
23 minutes ago, Slim! domotica said:
Wich firmware has youre doorbell6?,
version 1.5
I know there are problems with hc3 with version 1.5. and 1.6, only 1.4 works with hc3
perhaps you can downgrade to 1.4 and test it with youre hcl
(1.5 works on the HC2)
1.5 also works on my HC3, had to reconfigure the device however  after including it for the first time.
