Plugin (HC2) unable to find Philips Hue IP
Guest jodohl
In my ongoing odyssey to integrate an IKEA Trådfri Bulb in my HCL, I reached the stage of installing the Hue Plugin. I sent it searching for the Philips Hue, but without success. I have confirmed the Hue is working, since it is able to control the IKEA bulb. I have also confirmed the IP address on my LAN by using a network scanner app.
But even entering the 192.168.1.101 address manually is to no avail.
I have of course taken all the desperate measures, turning everything on/off, resetting the router etc etc.
Ideas anyone?  .
No Ideas I am afraid, but I have the same problem. I have also added the IP adress manualy into the system, still dosent work. My quest is with Hue bulbs, not Ikea, still the same problem. It might be the routher, since you must add both systems to it via ethernet and not wifi. If the router separates the segments the systems wont see each others IP adress. But if thats the case, then the whole idea on how this should integrate is fault, and should never be advertised without that information. I hope I am wrong.
