LaMetric Clock starting Timer via API
Hello
I'm using the LaMetric Clock for notifications for 2 jears. Now i'm trying to start a 15 min. timer on the clock together with the preaheating of the espresso machine.
I adapted the code from the LaMetric API description, but the clock do not react to the code:
Action “countdown.configure”
Parameter Format Description
duration Integer Optional. Time in seconds.
start_now Boolean Optional. If set to true countdown will start immediately.
Source:
LUA Code:
Maybe somebody can give me a hint?
Thanks!
try to serach first
HC3
for Hc2 just 5 mins
HC2
@Vaiolux
/monthly_2020_10/image.png.ba517bc90b4ce8cd0057c6ab294e914a.png" />
