In Egypt we have only two wires for any switch live and neutral no ground so what i should do install the double switch
You should wire up according to the manual
You may be confusing a switch wire for the neutral, and neutral for ground...you don't need a ground wire.
If you aren't confident you should get an electrician to do it for you.
