Boiler-radiator heating based on inside + outside sensors
hi!
just find interesting as for me formula
local tBoilerCalc = (tBoiler + SL * (setPoint - tOutside) + OF) + (SL * RI * (setPoint - tInside))
where
tBoiler = boiler temperature or sensor on boiler out pipe
tOutside = outside temperature
tInside = the current inside (room(s)) temperature
setPoint = req insde (room(s)) temperature
constant or settuped additonal params
RI - house insulation coefficient ( 20 - your house is naked :)  0 - a very coll / maximum insulation)
SL - thermoregulation curve (can be from 1.0 .. 3.5. just
OF - temperature curve offset
local setPoint = 22.0
local tBoiler = fibaro.getValue(720"value")
local tOutside = fibaro.getValue(1946"value")
local tInside = fibaro.getValue(1945"value"
local RI = 15
local SL = 2.5
local OF = 0
print(tBoilerCalc)
25.649285714275
5 answers to this question
What are you calculating? (what is  tBoilerCalc).
I put it in Excel and it doesn't make any sense.
I'm using something similar to calculate the temperature of water going into floor heating to regulate mixing valve
including the return water temperature to calculate current floor temperature.
    @Edo
    what temp i sgould setup on the boiler what i have setPoint temperature in the room.
    for floor heating we should use another coefficient
    What kind of Boiler (Furnace) do you have that you can regulate the temperature. (without mixing valves)
    Edited by Edo
    Kospel (polska)
    btw my wife never mixing valves... just once "configure" as she comfort and all.
    idk.
    I wish i could keep my wife on 22 Celsius.  It would save a lot of money ?
    Regarding the Kospel boiler: is it a furnace or condensation unit ?  As if it is a condensation unit, the thermoregulation curve and offset should be inside it already. And the condensation units should always be left on.
