Heat Controller + HC3 heating schedules issue
Iztok88
I have an HC3 + 5 pieces of the Heat Controller thermostat head(v4.6)
I am not trying to do anything complicated, basicly just create some heating schedules.
The problem is everytime a new schedule is supposed to become active nothing happens. Temperature from the last one is still active.
If I do a manual synchronization of the THead via Fibaro UI the temperature goes to the set temperature for a few seconds and then goes to 23 degrees.
If I manually overide any user changes to the schedule, by holding the head for 5 seconds same thing happens. Temperature goes always to 23 degrees.
This is an appartment building where the radiators are not yet heated by the building manager. Though I don't think this should matter?
The heads are connected to the bluetooth temperature sensor which works ok.
The heating schedules I'm using to test are like this:
Mode: Heat
9:00 set temp 12, 10:30 set temp 26, 12:00 set temp 13, 13:30 set temp 26
Temperature from the temp sensor is basicly constant at 18-19 degrees.
There is a thermostat in the main room that isn't replaced by a z-wave type thermostat yet, but I don't think this should matter, should it?
I feel like there is some simple setting I am missing.
Any suggestions would be very apreciated.
I just bought 3 packs (heat controller + external temperature sensor) and installed them in three rooms.
The same situation occurs in my case: the schedule is not followed by any of the heat controllers although the external temp sensors read the correct room temperature.
I thought that, given I use a Fibaro solution for 3 years (HC Lite), it's a good idea to use the heat controllers from Fibaro too. Bu I think I've made a mistake purchasing these devices. They have some unsolved problems for quite some time now and FIbaro doesn't seems to care a lot about this.
Edited by Cosminium
