Temperature to high!
kallecux
Why that? Does anybody know why this?
HC3 - newest firmware - Heat Controller newest firmware.
Thanks in advance.
/monthly_2020_10/1239856393_Bildschirmfoto2020-10-11um18_17_12.png.352ee5ba3df755632c8b1ebd8e4aafd2.png" />
4 answers to this question
I have the same problem and, yes, I use the extra sensor with my heat controller.
The thermostat was configurated at 20° and we're faaaaar away from it...
Hi All!
One of our customers has the same issue with HC2 (4.6) and Heat Controllers (4.7) without external sensor.
I tried a lot of things. Soft & hard reconfigure, factory reset, re-calibration but nothing solve the problem.
It seems that the controller doesn't close the valve after reaching the set point but I don't know why. When I turn the controller to minimum state it close the valve and the hot water stop flowing.
I've opened a ticket to Fibaro support I don't have any idea why do this the system.
/monthly_2020_12/image.png.3efb165103cbb62c6abcc55c0ab1aafe.png" />
For me the same problems.
I have 5 heat controllers ( only 3 active anymore ).
All the ones with firmware 4.7 i dis-abled because the kept falling in error ( calibration failure ).
The one with firmware 4.5 worked for a while very good but recently without any changes it keeps heating and when send command cooldown or turn aff it is not responding ( no errors in the log ).
When this happens i have to do a manual callibration on the button, reboot HC3 and then it works again and it cools down the radiator.
The thermostat controllers i really dis-like because they just don’t work and aren't reliable.
Thinking about to sell them all and go for an other system set up. maybe only for the thermostats and maybe i will thro out the complete Fibaro system.
Fibaro is just not keeping promises, they don’t give good service and response.
Thinking to go for Zigbee themostats and maybe a complete Zigbee system when no changes are coming withing this new month in the new year.
Fibaro sells a system under false pretenses, they say it support lots of protocols but for no it still only supports Z-wave.
