How to reference embedded attribute using Json.decode
UriT
Newbie scripting question. Thanks to all the posts here I have learnt a lot in the last few weeks ... so thank you for all your knowledge and insights and generosity for sharing.
I am adapting Yamaha MusicCast QA.
I have worked out how to query the Yamaha depending on what it is playing eg Tuner or Spotify etc.
My query as per below code
  local queryinfo = "/YamahaExtendedControl/v1/tuner/getPlayInfo"
              urlinfo = url .. "" .. queryinfo
              self.httpClient:request(urlinfo,
                  options={method = "GET"
                  success = function (response)
                    if (response.status >= 200 and response.status < 300then
                      jS = json.decode(response.data)
                      self:debug(response.data)
Returns the following response
 {"response_code":0,"band":"fm","auto_scan":false,"fm":{"preset":4,"freq":106500,"tuned":true,"audio_mode":"mono"}}
I have learnt to reference the band I can simply do something like
 band = (js.band)
The question is .. how do I extract the "freq" value?
if I do freq = (js.freq) I get "nil"
How do you parse the values embedded within a secondary {} ?
  • Yes that is the one I am adapting .. Sorry I didn't quite understand
    Did you mean..
    freq = response.data["freq"
    self:debug(freq)
    But still get nil
    I had tried just
    freq = data["freq"
    but got
    main.lua:215: attempt to index a nil value (global 'data')
    OMG. OK
    local raw =  '{"response_code":0,"band":"fm","auto_scan":false,"fm":{"preset":4,"freq":106500,"tuned":true,"audio_mode":"mono"}}';
    local xlat = json.decode(raw)
    print(xlat["fm"]["freq"])
