walli switch and RGBW controller 2
I would like to on/off RGBW using walli switch, is it possilbe? On the output form walli switch I have 240V, so I cannot connect it to RGBW IN1 contoll input. Is it possible using wires?
Michal
Not possible using wires. You could use standard mechanical bell press switches, and wire it all up as per the diagram in the online RGBW manual.
But why use wires when you can use z-wave ? ?
You can write a simple block scene, using the walli switch values as triggers, and RGBW as outputs. You can use walli parameter 40 as the trigger for starting the nominated scene too.
More convenient way is to use association or build the scene(s)
