Hi I have a problem with the 2N helios gold plugin.
I executed the manual that I downloaded on the fibaro marketplace to the letter, but unfortunately, already at the first setting I cannot see the cam of my 2N verso device. I enter the ip address of the intercom, username and password but nothing. I configure the API settings on the intercom as per the instruction manual then I make the settings of the sip server but the device does not register with my fibaro home center 3. The error message that appears on the 2N is 401 Unauthorized. Does anyone know how or where am I wrong please?
9 answers to this question
Hi i have the same problem with my verso
in the hc 2 it works
in the hc 3 it don't work
Edited by Stef4321
same problem
Edited by silvertav
    Allora non sono io , quindi ci sta un problema d'integrazione del plug-in sulla HC3
    Did anyone fix the issue with 2N and HC3 integration?
    I am still hoping someone has found a resolution to this issue -> Home Center 3 '2N Helios Gold App/Device' not working with Helios IP intercom.
    did you tried with latest beta 5.113.60? Wondering because since 5.112 Beta 2N should be fixed, see release notes,
    Bug fixes:
    Plugins
    2N Helios plugin does not work correctly.
    great pick.. I will give that a go and will share my findings.
    hello did you manage to associate your 2N to Fibaro HC3 in the end?
