Block Scene not functioning
I created a simple scene for my HUE lights:
  • Motion detected
  • time between x and y
  • Lamp not on
Then it should switch on my lights. Attached a screenshot.
When I only do motion detected and the time no issue. Lights will switch on.
When I add the lamp for the check if the lights are not already on the scene will not function anymore. Lights will not switch on.
How come?
@markb81
because the trigger is turned off, so if the light goes from on to off, so if the light is off it will not do anything.
Better (something that fibaro has to change) that you can say light is off in stead is turned off
there is a workaround for this
create a variable, toiletlight with on and off
create 2 extra block scenes
if toilet light is on then set variable toiletlight to on and visaversa
change youre original blockscene, erase the toiletlight is turne off and add the variable is off
hope you understand what i mean.
Edited by akatar
I solved it through Brightness. Check if Brightness 0%
Edited by Mickler
    Good one! Thanks for that. That will probably work.
