Keyfob doesn't wake up/work until I disconnect the battery
imd
I have a problem that I didn't saw it before.
When I use my keyfob, sometime often it doesn't work at all. I need to disconnect the battery and put it back on to start it. Even if I press "O" and "+" to wake up, it doesn't show any light or doesn't make anything.
I tried to delete it and to reinclude it but it make the same thing.
When I reconnect the battery, I can use perfectly the scenes in my house. I configured a sleep in 60 second and make a combination for unlocking it.
What can I do to resolve the problem ?
  • Yes, it's green when I make the procedure of verification
    Checking battery level:
    KeyFob automatically warns about low battery with 3 magenta blinks.
    1. Click
       and minus simultaneously.
    2. Click triangle or cross until LED glows cyan.
    3. Click cross.
    4. LED indicates battery level with a smoothly transitioning colours, where:
      • Green – 100%
      • Yellow – 50%
      • Red – 1%
    5. Wait 2 second or click any button to exit.
    Remove the battery.
    Wait 10 minutes.
    Replace the battery.
    Do battery check again.
    Had also issue, with battery status. After some testing, i did like above, and the battery status was suddenly red. So I replaced the battery and issues where gone. Id I have issue's again I willl do the same again.
    looks like the KeyFob doesn't realize the battery is dying.
