According to the needs of customers, I designed and produced the scheme of 0-10V dimming for fibaro RGBW module. Through the conversion board, the RGBW module was separated into four channels of 0-10V dimming signals. At present, the test results are very stable. We can connect a lot of 0-10V drivers on each channel to control the dimming of a large area, whether it is constant voltage or constant current
