More possibilities for creating RGBW modules!
My colleagues and I deeply studied the RGBW module. We found that four channels can be converted into four channels of 0-10V signals to drive dimming. So we designed such a circuit board. After testing, we met our expectations. We will apply the RGBW module and circuit board to practical projects. I don't know what you have good suggestions. I hope to hear your suggestions. Thank you !
    We use RGBW module to dimming the downlight. Each channel can be connected with one downlight or several downlights. There are some dimming schemes similar to Dali in this control mode. We are ready to use them in practical projects
    We have tested that the 0-10V dimming scheme with constant current and constant voltage can be controlled
    The installation method only needs to put in the switch box, and install the switch outside
