Home Center 3 and Zigbee, Bluetooth LE, 433MHz, WiFi, and 868MHz ?
Soft
I need to replace the HC2.
These days it would be smart to find a solution that will support multiple protocols when there are so many different products out there.
Can I assume support for any of the ones in the title, or should I assume that Z-Wave is the only one with HC3?.
I also have  wall mounted iPads, and it seems that there is no iPad app currently for HC3?, when will that be available ?
I would direct that question to Fibaro. On this forum you will only receive our guesses. But with Homecenter2 Fibraro promised a system where you could buy groceries online and use your center as a remote control for your TV. You could also send sms. Well, nothing were ever delivered. Oh wait. In Poland you could use sms.
So what is your guess?
