Turning off valves that control heating in combination with heating panel - FIbaro thermostat heads used
Hello people,
Is there a way to read thermostat head status - specifically the status from schedule when the thermo head is not open?
Description: Appartment has combination of underfloor and radiator heating. Underfloor valve is opened via single switch linked with room temperature sensor. Radiator heating is opened via thermo head with dedicated sensor.
Appartment has main valve that lets hot water into the heating system.
Everything is managed through heating panel.
I can turn on the main valve with scene: if any underfloor valve is open or if any thermohead is in "heat" state then turn on main valve - it works.
But I have problem with turning off the main valve. The scene should be something like this: if all underfloor valves are closed and all thermoheads are "closed" then turn off main valve.
The problem is that I cant get it to turn off the main valve.
OFF command does not work since the thermoheads dont go into OFF mode
I guess I need a mode or variable that says "thermohead is in schedule but currently closed"
Please advise
