GarageGate Smart Implant (FGBS-222) via FHEM
Hi there,
I´m pretty new at this and am currently trying to automate my GarageGate (Teckentrup one-button) via Smart implant. I read quite a lot but am facing the following problem: I want to use IN1 for a reed sensor to check whether the gate is open or closed. I wired it against GND and closing the reed is shown in the FHEM event monitor. However, it shows "on" and immediately after "off" although the reed remains closed - I configured IN1 as Bistable button. I obviously do not want any direct relation of that IN1 to any of the two OUTs.
Any input is highly apprechiated. I have to admid that this is true also for the FHEM programming. What I basically want is a "Close gate" event (that only triggers when the Reed on IN1 is open) and the opposite "Open gate" event.
Perspectively I´ll try to add a photoelectric barrier - but not right now. Need to find a bit more of my way into this before adding more complexity...
Thanks!!
Christian
