Lux value not changing in lua script
I have a simple script to determine on which lux values I want to trigger. It should output the current lux value. It does do that (I think) however even if I turn the lights on very bright the lux value will not change. What should I do to get the current lux value each and every time?
-- This script can be used to print the current lux value of a Light sensor set in md1 variable
%% autostart
%% properties
%% globals
local jT = json.decode((fibaro.getGlobalVariable("HomeTable")))
-- Get Device IDs
md1 = jT["Badkamer/Badkamer Light"]
-- Set required variables
local lux = 0;
local lightLevelName = ""
-- Get detected Lux value
lux = tonumber(fibaro.getValue(md1,"value"));
if lux < 1 then
    lightLevelName = "Pitch Black";
  elseif lux < 10 then
    lightLevelName = "Very Dark";
  elseif lux < 300 then
    lightLevelName = "Dark Indoors";
  elseif lux < 800 then
    lightLevelName = "Dim Indoors";
  elseif lux < 3000 then
    lightLevelName = "Normal Indoors";
  elseif lux < 5000 then
    lightLevelName = "Bright Indoors";
  elseif lux < 10000 then
    lightLevelName = "Dim Outdoors";
  elseif lux < 30000 then
    lightLevelName = "Cloudy Outdoors";
  elseif lux < 100000 then
    lightLevelName = "Direct Sunlight";
  end;
-- Printout to console
print("Current LUX Level of Light Sensor ",md1," is: ",lux, " which can be compared to ", lightLevelName)
Hi @markb81,
Which sensor do you use for measuring lux?
    Fibaro Motion Detector
    And in your dashboard you do see different lux values during the day?
