Set Value via HTTP out of Fibaro HC3 Scene
I try to set a value on a HTTP target.
In this case i try to gather the "power consumoption over time" cause Fibaro remove any usefull diagrams in HC3.
This works quite well for me in a browser:
http://IP:8087/set/javascript.0.fibaro.WP-Flex_Power?value=XX
I can cut & paste a debug output from my scene and the value will be set, but within the scene nothing happends.
The same approach works for me in QuickApps:
http = net.HTTPClient({timeout=3000})
url = "http://IP:8087/set/javascript.0.fibaro.WP-Flex_Power?value=XXX"
http:request(url, {})
I tried also to nail down the method but nothing changed for me:
Example:
        options={
            method = 'GET'}
Edited by moltos
6 answers to this question
    Error message: 500
    "error: no value found for \"javascript.0.fibaro.WP-Flex_Power\". Use /set/id?value=1 or /set/id?value=1&wait=1000"
    But as mentioned in my browser or from a Quick App this works as to expect.
    is it Influx db?
    lelf
        operator = "all",
        conditions = {
                type = "date",
                property = "cron",
                operator = "match",
                value = {"*""*""*""*""*""*"},
                isTrigger = true
    right
    saveByDeviceID("PhaseA"1149)
    saveByDeviceID("PhaseB"1152)
    saveByDeviceID("PhaseC"1146)
    saveByDeviceID("PhaseA_Energy"1148"power")
    saveByDeviceID("PhaseB_Energy"1151"power")
    saveByDeviceID("PhaseC_Energy"1145"power")
    Edited by 10der
    No its not influx, I only use history in iobroker as workaround.
    With simple API you normally can directly change the value with shown url.
    My error does not make really much sense for me.
    In your case you have to send the data (value=1235) in the body right?
    9 hours ago, moltos said:
    Error message: 500
    so as the error line ends up with \, the error seems to be there, and exact there is ? sign.
    You have to url encode the bold part, like:
    Edited by tinman
    • Thanks 2
    See answer by @tinman
    Many thanks @
      this works for me .... I would never have found this without your help.
    Edited by moltos
