Walli Dimmer parameter 13 code LUA
bonjour
Je souhaite savoir s'il existe un moyen de contrôler la paramètre 13 via un une scène (code lua) ?
I want to know if there is a way to control parameter 13 via a scene (LED frame – brightness)  (lua code) ?
thank you in advance?
You can do it in scenes, just choose the trigger (in my case sunrise with delay 2 hours, then insert the group of walli's on the action, select the brightness set You want.
After that, You can transform this scene to lua, to find out, what commands You can use in Your code.
/monthly_2020_11/image.png.080bd9b1feb3bba907b31c2a76169d22.png" />
