fibaro.debug console logging
Is there a negative performance impact is you have fibaro.debug console logging enabled in all your scripts?
In each script I write a line tot the console for debugging. Will it impact the performance of the HC in the end or can I just leave it?
I have all my scenes and VD's with logging turned on and I didn't noticed any degradation in performance. Still it is good practice to minimize logging and turn it on only in case when debugging is needed to find problems.
I'm implementing different levels of debug logging in all my code with possibility to stop it entirely and only to write log in case of errors.
    Do you have an example how to approach this? Do you work with if routines ( if debuglevel = 1 then output ) or do you have a beter approach?
