Aeotec Door / Windows Sensor 7 - firmware update on HC3
mariokil
I'm trying to update firmware in my Aeotec sensor (v. 1.00 to v.1.01). Unfortunately HC3 not "see" any updates.
Is it any special procedure ?
Thank you
9 answers to this question
Thank you
Yes, you need a aeotec zwave stick for that.
Some compagnies work together with aeotec so that you can use their controller to update
fibaro is not one of them
  • Thank you for prompt update ?
    Looks like I only need to use fibaro sensors :( ? ... or buy additional unused hardware ?
    Just buy a secondhand aeotec stick. they are around 20 euro (i did)
    You will also need it for the doorbell6 etc
    Thank you
    Hello mariokil
    Does your Aeotec Door / Windows Sensor 7 sensor work with HC3?
    Edited by RudyT
    Quote
    All Zwave devices, regardless of manufacturer, work in HC3, but not all devices that Fibaro creates a template for.
    If a template is missing after installation, you can, if necessary, create a table with the parameters that you need to adjust.
    Not always,
    Some devices require zwave classes that hc2 doesn't support.
    Also according to fibaro support:
    If the device is a third party and doesn't have template in our system,  all functions cannot work well.
    Thank you for the template, I will forward it on to our engineers.
    Pozdrawiam/Kind regards,
    <name removed>
    Tech Support
    I have Aeotec Door / Windows Sensor 7 ZWA008 version 1.1. Maybe i'm doing something wrong. If I remove the shell, then it works. If I put the shell back on, it stopped working after a few minutes. I think it has something to do with wakeup.
    I have another recessed door sensor 7. It works very well. But it has endpoint 0 group 1 multichanel and singlechanel as an association. The Door/Window  sensor 7 doesn't have it. I tried to add it, but i can only add one of them, singlechanel or multichanel not both of them.
    Recessed door window 7 ZWA187
    Edited by RudyT
    So, the Door/Window Sensor 7 works. But but this one had really a defect. Another devices works fine.
    Thanks to Aeotec for Support!
