How to use single switch 2 for bathroom ventilator
Ericj
Probably easy for gurus, but not for me.
I want to be able to switch on the bathroom ventilator using a toggle switch. When switched on the ventilator should be switched on. When the toggle switch is off the ventilator should run for another 30 minutes, so switching off is delayed.
I used parameter4 to set the time but when the toggle switch (S1) is on for 45 minutes the ventilator switches off at 30 minutes.
So what parameter do I have change to get the on switch to be indefinite and the off switch delayed?
Thx
Eric
  • Problem solved, AFAIK this delayed off is just not possible in this single switch (213) . It is however configurable in the double one(223), you can set auto off or delayed off.  Just wondering why Fibaro left this option out in the single version.
    Now I've got to redo the physical installation. :-(
