Fibaro single switch fgs-214 newbe need help
In switch of my light I got 2 live wire+ because second is for other sockets in my house and it must be always on.
I don't see in the wall neutral leads - is it ground wire? Is it mandatory?
How should install fibaro swith to have on second live wire+ always on for rest of my socket in the house?
Is should be like below or should I change S1 with Q?
Is "Load wire" from the wall in port IN connected correctly or should be Q? :)
I will be grateful for help.
Best regards,
Jack
Yes you do need a neutral for this module. You may be better off installing it behind the light fitting where there will be a neutral.. Or else use a Fibaro Dimmer because it doesn't need a neutral.
Wiring diagrams are in the online manual, use an electrician if you are in any way unsure.
    I'm not sure, that's why I'm asking here
    • 2 months later...
    did you find a solution? I have these fibaro, and all i want is to conect them to a wall light switch. but i cant make my wall swtich turn on or of, and i cant control the fibaro to even turn that light on. Can anyone help me with the wirring diagram? i have a neutral installed there.
    I think the diagrams in the manuals are eloquent and exemplary enough. Since you didn't provide a photo, a more accurate description of what equipment you have ... it's hard to help you.
    First, fill in all the recommended data in the profile, such as where you are from, what equipment you have, and you may be surprised at how the relevant answers come together and maybe even an offer for implementation ...
    Hello Martin,
     and thank you for the reply. i was able to connected it :) thank you. the problem now is that i need to change the parameters of the module.
    parameter 20 set to value 1. and i dont have the hub. ive been trying many things but no luck. Do i need to but the hubto be able to switch these? because on Home assistant the device is unknown so i cant change anything :( this doesnt happen to the wallies i am not sure why. but now im stuck with this.
