michal85pl 15
I purchased an FGS-224 for testing and I have a problem:
1. Adding a module takes 14 minutes:
[29.10.2020] [18:19:47] [TRACE] [ZWAVE]: ID 502: Setting value 0 for parameter 162
[29.10.2020] [18:19:47] [TRACE] [ZWAVE]: ID 502: Setting value 0 for parameter 163
[29.10.2020] [18:19:47] [TRACE] [ZWAVE]: ID 502: Setting value 0 for parameter 164
[29.10.2020] [18:33:36] [TRACE] [ZWAVE]: ID 502: Device configuration finished
[29.10.2020] [18:33:40] [TRACE] [ZWAVE]: ID 502: Device configuration finished
2. After adding, the module does not respond to switching from the HC3 level. Only on physical buttons.
Anyone had such a problem? Am i doing something wrong?
best regards
Edited by michal85pl1 answer to this question
