Error HC2 sending http via VD using Net.FHttp
I try sending a string via http to another device, via a browser it works fine:
http://192.168.200.242:8080/json.htm?type=command&param=updateuservariable&vname=NTFF&vtype=float&vvalue=21
I tried to do this via the commands in a VirtualDevice:
FIBARO = Net.FHttp("192.168.200.242", "8080")
FIBARO:POST("/json.htm?type=command&param=updateuservariable&vname=NTFF&vtype=float&vvalue=21")
Debug returns an error in line 2. I tried a lot of things (post/put/several other things), but nothing seems to work. Any idea?
I'm using HC2 4.6
Niels.
    Solved. I had to use GET....
