LUA and "/app/history"
Good morning,
In "/app/history" there is a lot of information about the causes of the change of state of a sensor.
This information would be very useful to build much more intelligent scenes that could be based not only on the occurrence of certain events, but also on the causes that caused them.
I make an example; in the change of state of a binary switch I can analyze which user has determined it.
This information seems to be historicized (you can go back in time).
Is it possible to access this information from LUA scenes?
Thank you.
Lorenzo
5 answers to this question
api.get("/events/history")
    Good evening,
    I explained myself badly.
    My question is whether it is possible to access via API the data displayed on the screen
    I enclose a screenshot for your convenience.
    Greetings.
    Lorenzo
    8 minutes ago, LorenzoGrigoletto said:
    Good evening,
    Greetings.
    Lorenzo
    Yes, and that display is rendered with the data from api.get("/events/history")
    You asked if it was possible to access it from Lua, and that is the way...
    sure, with
    /api/history?from=1604768863&to=1605114463&type=time
    or
    /api/events/history?from=1604768863&to=1605114463&type=time
    You can use different filters of coure, check swagger events history
