As I am performing housekeeping on my HC3, I need to remove a device. Problem, the device itself is no longer available (broken). So removing bij the learning mode is out of the question ;-) How can I remove this device from my HC3.
Kind regards, Huub Nabben
If you go to devices -> click remove device-> click start, then you get a garbage can behind you're devices. -> click the garbage can. Is a sort of Force removal.
Edited by Flash
    Hi Flah.
    This was the first time I used the forum. Ans it works. Thanks very mutch for your help.
    Kind regards,
    Huub Nabben
