walli dimmer/roller shutter - not configured
I have the problem, that both says they are nbot configured and I not getting this away.
I am able to set parameters, but dimmer is not reporting it state back, when I switch it manually.
May
Did you included them in secure mode? If yes try to exclude them and include in non secure mode.
If not do a soft reconfig. If this doesn't do the trick bring them closer to the HC and do a soft-reconfig. Or exclude/ include the walli near the HC.
Then move the walli back to it's original place and do a mesh reconfig of the device.
