RGBW2 user-defined programs
Guest JoergiNRW
Guest JoergiNRW
Hi @all!
When renovating my kitchen, I also changed the controller from a Fibaro RGBW to the newer (better? ?) RGBW2.
Everything worked normally with the older controller. But I am not possible to write user-defined programs to the controller.
The Interface switches to "on" and the program seems to be active also. But nothing happens with my lamp.
When the lamp is switched on and I want to change to a program, it only switches off.
The predefined programs work without any problems.
I hoped, there is a new firmware. But when I tried to watch out for this, I don´t even find a button for checking for updates. ?
Actually the device has Version 5.1 and my HC2 has V 4.600.
I read in some other forums, that other users have the same problem. Meanwhile is there any solution from Fibaro?
Thanks and regards,
Jörg
Edited by JoergiNRW
correction of typing errors
@jgab did you ever find a solution to this?
I want to setup Christmas flashing lights, but can't find a way to do it.....maybe I'm looking in the wrong area, but on the HC2 I can't easily see how to do it.
@alex88 I have been looking for the same. Have you found a work around for this yet? I’m thinking of creating a lua scene or function for my rgbw2 & go from there since i cant find anything
