Help in HC3 lua coding
Hello.
Anyone please can explain me what is wrong with this simple code?
  conditions = { {
      id = 94,
      isTrigger = true,
      operator = "==",
      property = "centralSceneEvent",
      type = "device",
      value = {
        keyAttribute = "Pressed",
        keyId = 1
  operator = "all"
local light = tostring(fibaro.get(42"value"))
print("" ..light)
if light == false then
fibaro.call(42"TurnOn")
nothing happen when i run the scene.
thank you
5 answers to this question
9 minutes ago, gabrielflow said:
Hello.
  conditions = { {
      id = 94,
      isTrigger = true,
      operator = "==",
      type = "device",
      value = {
        keyId = 1
  operator = "all"
print("" ..light)
thank you
You compare light to a Boolean but you assign light a string.
    how would it be right?
    thank you, but not working :(
      operator = "all"
