API Token gets corrupted in LUA
I have access to an API towards my Solarsystem which im trying to setup.
To get to the actual data i need to first get a Token by providing username/pass which i then use to send together with the next request and this is where it stops.
I can do the same thing in Postman and it works.
The Token can look something like this:
eyJhbGciOiJIUzI1NiJ9.eyJyYW5kb21LZXkiOiIyMjRmZTVmNC1lOGE1LTQ5MmUtOTgxNC03ZTc1OTU1ZmI5ZDQifQ.3DgsI-vX-wZgy5X_dgqHswOwOCnw5QcYVWF0wHfJp58
When i print this out in a scene before using it i can see it always performs a line feed after the first '-' in the string.
When examine the string in notepad++ there is no \r or \n (CR|LF) but somehow, something is happening with the Token string and i suspect that this is the problem..
Im saving the Token as a global var and then use it in the header (xsrfToken):
options = {
                headers = {["XSRF-TOKEN"] = tostring(xsrfToken), ['Content-Type'] = 'application/json'},
                method = 'POST',
                checkCertificate = false,
                data = json.encode(pLoad)
Maybe someone has met the same problem?
BR
4 answers to this question
    After some more investigation i found that the token is correct, but reading some more in this forum it is probably due to the header, XSRF-TOKEN, that is not supported..
    Hi again..
    I have tried some more to get this working and since its failing when using requests from Fibaro Scene i tried to setup a simple console app in VS to run the same requests (using RestSharp) with C# but i get the same response:
    status":200,"data":"{\"data\":{\"failCode\":306,\"immediately\":true,\"message\":\"USER_MUST_RELOGIN\"},\"failCode\":306,\"params\":null,\"success\":false}"}
    There is no problem getting the Token but when trying to use it in the next request, i just cant get pass this failure..
    So i´m hoping there is someone good at HTTP Requests and can spare a couple of minutes to help out (I really want this working ;( )
    Here is what i have to do:
    And its working in PostMan but i´m probably doing something wrong, just cant figure out what!
    5.     Interface of Plant List
    .. is where im stuck..
    Really would appreciate any help, Thanks!
    Its working with RestSharp after i added some cookies from the first request but how do i add cookies in lua to make this work from HC2?
    Were you able to fix this problem? I'm gonna do the same.
