I have just migrated from HC2 to HC3. There is very little done in the graphical interface in HC3 compared to HC2. You will have to do a lot yourself,
for example via the REST API. For this to work you will need in depth documentation of the HC3. One example, in a scene you need to set conditions
for the sceen to run. I have read the Lua Scene HC3 manual which gives some high level information. Looking around in the Fibaro Forums I notice
that it is much more than can be done in the condtion/trigger section of a scene than is officially documented from Fibaro.
My suggestion is thus to put much more work in a more detailed documentation what can be done in the HC3 system.
Kindly regards,
Bernhard Stockman
Looks like new born babe issues... good that I hold my horses with HC2. BTW..  many old users went away from Fibaro. Their support sucks..
Any good solution to replace fibaro? Without replacing z-wave devices?
